I have a few questions for those of you more informed.BTW p5k asus board
1.Is 9 the only multipler for the e6600?
2.I purchased corsair xms2 cm2x1024-5400c4 675mhz modules, I should be able to o/c fairly easily to 3Ghz @ 333x9 right? What would be the max o/c do you think i could achive outta these modules.
3.How is the xp-90c cooler for these cpu, i like the look of them,, or should i go with water cool for higher o/c's--if so what do you reccomend..
thanks
thanks
