Need Advice for Gaming mITX *or* mATX
MysticSoup
1. What will you be doing with this PC?
Gaming (specifically Starcraft 2 and nothing more) and web browsing mostly. It will also be for school work. I plan on using two 24'' monitors on this setup too,
2. What's your budget? Are tax and shipping included in this budget?
$550 Canadian funds, shipping and tax included. Give or take $30.
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
I live in Waterloo, Ontario, Canada. There is a Canada Computers store within walking distance. I normally shop at Canada Computers, ++++, and Newegg.ca, but shipping usually kills the deals or lack of stock of items I want.
4. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
I'm looking for a mITX / mATX board and mITX / mATX case.
I can't answer this question properly because my budget determines what I'm allowed to get, right? I really want mITX sandy bridge but I know it will go over my budget. See question 5 for more details about this.
5. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply.
I'm able to reuse the following:
Asus M2A-VM AM2 mATX motherboard
AMD Phenom II 940 Black Edition 3.0ghz
4gb (4 x 1gb) DDR2 ram (corsair, but I forget the model. They're PC6400 modules)
Gigabyte GTX 460 1GB
OCZ ModXStream Pro 600W Modular power supply. Here's my attempt to be specific..
86 mm Height x 150 mm Width x 160 mm Depth
Part number OCZ600MXSP
People have complained of its shorter cable lengths in the past. Great! I need smaller lengths for this build. It's actually pretty bad--25A x 2 on 12V. But it should be enough, right? *Gulp*
OCZ Vertex 2 60 gb SSD (older, 35nm process version)
WD Caviar Black 1TB
CD/DVD ROM Drive
SATA cables
6. What specific features do you need in a motherboard?
The size of the system takes high priority. I built a system around the NZXT Vulcan and thought it would be good until the case arrived and it was far larger than I ever imagined for mATX.
Crossfire/SLI/USB3.0 is not on my priority list at all.
SATA 6.0Gb/s might be useful. I don't know if I might need it in the future.
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
I am hoping for 1920x1080 resolution on two monitors.
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
If it's cute enough I'll put it on my desk. If it's ugly I can put it on the floor or shove it in my desk. I define ''cute'' as Lian Li V351 or V352, or perhaps Silverstone Sugo SG05.
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I have screwdrivers and that's all. I am uncomfortable with cutting metal and doing mods of that sort.
10. How important is the noise/silence of this system?
Not much of a concern, but I am willing to stretch my budget for a more quiet setup.
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
It needs to be mobile enough that I can throw it into a duffle bag and carry it around a town.
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
I have a OEM copy of Windows 7 Ultimate.
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
I plan on making a decision by this weekend, and a purchase by Wednesday April 20th at 11pm (enough time to catch the new surprise sale while saving items in the cart from the April 13 surprise sale on ++++).
I have a feeling $550 is far too low of a budget.. if I just ballpark costs off the top of my head:
i5 2500k - $210
mobo - $150
case - $150
ram - $100
Already past $600, even with my transferable parts. Is there a chance of prices going down? If not in the near future, perhaps I can reuse my crappy, but alive AM2 board and processor again. My goal is just to downsize everything drastically.
One thing I'm still unsure of is whether you plan to overclock? You selected the 2500K so I'm guessing that you might want to... but you can actually save a fair amount of money by going with a non-overclocking setup AND going small matx. My prices are U.S. dollars, but these tend to be pretty close to Canadian these days.
Your stuff that will be re-used:
PSU
OCZ SSD
WD Caviar HD
GTX 460 vid card
CD/DVD drive
Stuff to consider:
Case: APEX TX-381-C Black Steel Micro ATX Tower Computer Case: $25
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154094
Motherboard: ASRock H61M/U3S3 (It even has 6 GB/s SATA and USB3): $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157236
CPU: Intel i5 2500 - )might as well go non-K model and save money since you won't be overclocking on H61 chipset) $210.
Memory: 8 GB (2x4GB) DDR3 1333 - G.Skill Value Series: $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231424
Final price tag: $395
Option #2: If you are dead set at going with a mitx build.
Lian Li PC-Q11 B (warning that your PSU cables will be right up next to front cooling fan): $110
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112297
Note that you can get the PC-Q08B for $10 more and it will give you better cooling and maybe more space for that PSU.
Intel i5 2500 - $210
GIGABYTE GA-H67N-USB3-B3 mitx motherboard - $115
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128484
Total $515 + ~$20 in shipping costs.
Thanks for the suggestion! An interesting first build option--but when you say I will save a fair bit of money getting a non-k version, I'm slightly confused. The i5 2500 is $210, but the i5 2500k is $220 (At newegg.ca and ++++). With those prices in mind do you think it might be silly to not get the k version, incase I upgrade?
You also recommended an H61 board--I was under the impression that H61 did not have any of these features such as SATA 6.0Gb.
Since this board does--how is it any different than a H67 board besides no GPU OCing?
All good questions. It is true that the standard H61 chipset only includes support for SATA 3.0 Gb/s. In this case, AsRock does it through an additional chip on the motherboard. From their website for this motherboard:
"2 x SATA3 6.0 Gb/s connectors by ASMedia ASM1061, support NCQ, AHCI and "Hot Plug" functions
USB 3.0 - 2 x USB 3.0 ports by ASMedia ASM1042, support USB 1.0/2.0/3.0 up to 5Gb/s
So both 6 Gb/s SATA and USB3 are "add-ons" outside the normal H61 chipset. I can't vouch for whether they are good or bad. I don't work for AsRock. ;)
Maybe somebody else will chime in and correct me but, those two additions plus the graphics overclocking are the major differences between H61 and H67. AsRock just found a cheaper solution by adding a 3rd party chip.
Yes, it's only about $10 of savings going with the non-K over the K version. I was just shaving money where I could. If you want to get the K with thoughts that you will be able to put it into a future motherboard with overclocking support... go for it.
I see. I was almost set on the first suggestion, but after looking at the mITX case you pointed me to (the PC-Q08B, not the 11B), I was instantly sold. It is drop dead gorgeous, and somehow only $100 CAD! I also get the feeling that I'll ''drop dead'' after dealing with such a case. I've built 4 systems in total so far, but all have been full ATX size except for the NZXT Vulcan (which also offered numerous features for cable management).
I suppose I just need to plan extra, extra carefully and be prepared to face challenges I never expected. Is it wise to perhaps assemble everything only after checking for DOA parts? ie: turn it on with everything out on a table first? I know that once I've assembled it all, I will lose my hair if anything goes wrong and I need to take anything apart.
Edit:
According to the review here: http://www.bit-tech.net/hardware/cases/2010/07/20/lian-li-pc-q08-review/3
The case may not fit full 160 mm depth power supplies. Should I be weary of this? It's the only source I found that had PSU trouble.
I agree that the PC-Q08B is a gorgeous case. I guess it is on the larger size of mitx but it's still mitx. I'm no expert on that case (I haven't built with it before), so
I'd suggest visiting the thread on the PC-Q08, though, before you dive in. http://hardforum.com/showthread.php?t=1481013
Apparently some folks have used a PSU extender in order to fit larger PSUs. Not the most elegant solution but it would work. http://www.lian-li.com/v2/en/produc...ex=249&cl_index=2&sc_index=34&ss_index=84&g=f
So that would add another $15-20 depending on where you got it. http://www.frozencpu.com/products/7...r_Supply_Extension_Bracket_-_Black_PE-01.html
Much thanks for the help!
@DesertCat: I read every page on the thread and it has been tremendously helpful. Thanks for the direction!
I'm almost positive I would be infinitely more happy ditching my 600w OCZ PSU and going for a shorter one, such as the Silverstone Strider 500w PSU, which happens to be 140mm as you mentioned. Would you guys say that even though the Silverstone is 500w, it is more reliable/better than the ocz anyway?
The suggested motherboard was GIGABYTE GA-H67N-USB3-B3 mitx motherboard - $115
I'm wondering if there's a difference between the Gigabyte and this:
ASRock H67M-ITX LGA 1155 Intel H67 - $105
It just so happened that the Gigabyte one had bad reviews on the Canadian newegg site which steered me away (until you guys can restore confidence or give me the green light for the ASRock).
In General Silverstone PSU's are very good. Not quite as good as seasonic, but way better then OCZ units. Plus for a mITX the Silverstone PP05 Short Cable kit comes in very handy. I used a Silverstone Strider 600 in a q11r. And yea definitly a tight fit, but doable for sure.
One other suggestion I would give is honestly ditch the SB build in favor of using your 940 & a Asus m4a88t-i 880g mitx board. Simply put the SB is a much faster chip, But its not fast enough to justify the nearly 200 dollar price premium over the CPU you already have and a much more feature packed motherboard. (and yes I know your CPU is > then the "supposed" 95w max RDP on the asus, but the board will run much higher including the black edition x6's)
I'll admit that I mostly put up the Gigabyte because it was in stock at Newegg.com and they've usually been good. There are some negative comments on that board up at Newegg. Makes me wonder if there aren't a few BIOS issues to still work out on it. The ASRock model you mention has been getting some good comments on this forum, though I haven't used it myself. I wouldn't be shy about picking it up.
From what I've read about the Silverstone PSU, most of the reviewers seem to like its performance but note that it has Chinese/Taiwanese capacitors. I honestly don't consider it that big of a deal, but the elite capacitors are from Japan. http://www.tweaktown.com/reviews/3720/silverstone_strider_plus_st50f_p_500w_power_supply/index1.html
From comments I've heard, the Silverstone PSU could probably be considered "upper middle class" while the OCZ is "lower middle class" in terms of where they fall out in the spectrum. It's got plenty of power for what you want to do with it. Especially considering using a 460 GTX and a sandy bridge processor, both of which are fairly energy efficient, your actual rig probably won't be pushing over 300-320W during heavy load game play. The Silverstone will give you some breathing room if you ever want to upgrade your video card (i.e. when the next great thing comes out).
@bastage: That's a really great idea, but are there any mITX 880g boards you recommend that wouldn't use SODIMMs? 240 pin just feels much easier to buy and resell and look for.
@DesertCat: I see, the PSU looks promising from the review still =]
To be honest, I never even thought of reusing the Phenom II 940. I could save so much going this route, and my build would be adjusted to something of this sort:
Lian Li Q08 - $110
880g mITX mobo - $130?
8gb DDR3 ram - $80
Random aftermarket cooler, I'll have to do more research on this. I currently use the Hyper 212+ but there is no way it'll be able to be reused. I was originally going to stick with the stock intel cooler from going SB, but this option would require me to spend an extra $20-$30.
Sorry for constantly de-railing my original topic and changing my mind and having conflicting ideas. You guys have been an awesome help so far in coping with my ignorance.
EDIT:
Waaaait a second! the 880g boards are AM3 are they not? My Phenom II 940 is an AM2 CPU, and AM3 boards are not backwards compatible with AM2 CPUs. It only works the other way around =(
I don't see an issue with the asrock board. I have owned two asrock boards and they were both solid as a (as)rock.
FYI: there is a combo on the i5 2500 with either the gigabyte or asrock board. The asrock combo is 299 and the gigabyte combo is 304.
So:
$300 for i5 2500 and mITX board.
~$120 for q08
$80 for 8GB of memory
You could use your PSU until you get more money (if you want another one) as it should be more than enough for an i5 and gtx 460. Reuse your ssd and hard drive. Sell the rest of your parts to either invest into a different PSU/cooler/accessories/beer/food.
If you do decide to stick with your Phenom and pick up a mitx board for it, be advised that your CPU cooler will need to be relatively low profile. Due to where the PSU is, many of these Lian Li cases can only accept a cooler that is 72-82 mm tall (depends on the model, don't know the PC-Q08 off the top of my head). Without going to water cooling, the most frequent low profile coolers you will hear around here are: Scythe Shuriken Rev. B, Scythe Big Shuriken (this fits the Asus AMD mitx board), Thermalright AXP-140, and Prolimatech Samuel 17.
It's fine on changing your mind a bit. That's part of the fun of all of this. Glad to share some of the info I've picked up around here.
It seems you are correct. The Asus board is AM3 and your AM2 CPU will not work. If the mobo was AM2+ then you could use either.
Whoops I didn't catch that. I forgot the 940 BE was an oddball & was an AM2+ chip only.. Ignore my suggestion.
+1 The M4A88T-I Deluxe is a fantasic mitx motherboard.
Psst not you too!
I can't use that board with an AM2+ chip =P
Just an update:
I went through with the order:
Lian Li Q08
i5 2500
Gigabyte GA-H67N-USB3-B3
8gb Mushkin Enhanced Silverline DDR3 1333 (I chose this 'cause it had heatsinks for the same price as the Gskill value ram)
Silverstone Strider Plus 500W
Silverstone Short Cable Set
Total: $683.69
That's pretty steep for just a case/psu/mobo/ram, but I'm pretty excited! I won't be building it until 2 weeks from now because of exams, but I'll make a new thread once I begin the build and let you guys know how everything turns out.
Right on. Good luck with the build. Those Mushkin Silverline sticks have been going for pretty reasonable prices lately.
Should be a nice looking and nice running system. I tend to be willing to spend $50-100 more on a build if I know I can look at it and be pleased with my choices instead of going "what if?" for the next three years. Looks like you eliminated the "what ifs?" :)
