Need advice for a low-powered mobo
swoody
I'm interested in building a low powered system that is still very capable However, I want this setup to use as little power as possible. I want to go with a 45w AMD dual-core CPU, and I would prefer to run this system from a pico PSU. I am not positive yet if I will be using an AM2, AM2+, or AM3 chip, but I would prefer to be able up upgrade to an AM3 in the future if I don't start out with one. My requirements are:
1) Low Power Usage - My highest priority is the power usage - I want this board to use as little power as possible. This is the most influential factor when considering a board.
2) On-board graphics - Something that could at least handle Blu-Ray playback (1080p) and has an HDMI output
3) Price - As far as price goes, I would really like to keep this under $60 including shipping, as I've found some pretty good boards in this price range.
4) Heat - I don't mind a board that gets warm if it uses less power than other boards, but if all else is equal, I would prefer a board that runs cool.
Some boards I've come across: (I'm still very open to other suggestions as well.)
- GIGABYTE GA-MA78LM-S2H AM3/AM2+/AM2 AMD 760G HDMI Micro ATX - $53 shipped
- JetWay JPA78VM5-H-LF AM2+/AM2 AMD 780V HDMI Micro ATX - $57 shipped
- ASUS M4A785-M AM3/AM2+/AM2 AMD 785G HDMI Micro ATX - $58 shipped
- MSI 785GTM-E45 AM3/AM2+/AM2 AMD 785G HDMI Micro ATX - $60 shipped
DDR3 has lower power consumption if you really wanted to lower it (means AM3 is needed). Have you considered mini itx with something like an Atom processor?
How much lower are we talking about here? I was planning on running either one or two sticks of DDR2 at 800MHz - I have these sitting around, so that's what I was hoping to use for this system. Also, my budget for this rig is rather low, I looked at pricing out an AM3 rig, and it came out to substantially more than than an AM2 or AM2+ rig. On top of that, being able to pick up used components inexpensively is pretty appealing to me ;)
I had thought about going with an Atom system, but I will be running Folding@Home on this rig 24/7. I like that the 45W dual-core CPUs will at least give me some better PPD. I also looked up Atom systems on NewEgg, and the cheapest setup I could find with an HDMI output was this Zotac for $137 shipped. That seems a bit more pricey than the Gigabyte mobo I listed above ($53) and a used, low-power CPU ($30), and wouldn't be able to match the performance. In addition to this, most of the mobos I listed above support AM3 processors, so once I save up enough to look into buying a new CPU I can pick up one of the new 45W quad-core Athlon II's, without having to change anything else on my system.
Hey, thanks for the links. I do use SPCR quite often, but it completely slipped my mind to make a post there :(
Never heard of LimeTech, but I'll have to look into them and see what they're about.
Don't enough for you to worry about. Are you interesting in undervolting?
Maybe check out ASUS EPU motherboards: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131391
It's just a vendor support board for their UNRaid product, but they go for low powered there.
I would be interested in undervolting this system, yes.
The EPU mobo looks interesting. I did notice that it does come with a lower-end IGP, and doesn't have an HDMI output, but I wonder how much power you can save with that EPU feature.
Ah, ok. Well I may have to look into the forum, and see how the community is there. I've received a lot of feedback to the various forums I've posted this topic to, but haven't really received any definitive answers so far on which mobos actually consume less power :(
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500021
Well, I've got one of those with a 45w X2 and it runs perfectly, awesomely fine but I can't give you any power draw numbers since I don't have a tester.
I can tell you that I can run it off of a 100w PSU that came with my Shuttle KPC without any issues. The fact that it's mITX means that it does consume far less power then an ATX or mATX board though.
Wondering where you get that idea from. All the same basic components are there regardless of the physical size of the board.
FWIW, when I see power consumption tests, I usually see ASUS as the worst. Gigabyte and MSI usually are the most power efficient.
Yeah, that board doesn't have HDMI but ASUS and Gigabyte both have those types of technology. Just find some boards thats have them and go with it :)
Sounds fair enough to me. I was actually leaning towards that Gigabyte board, so I'm glad to hear this :)
No that I care too much about their boards, but MSI boards are usually the most power-efficient.
I don't think that changes much, but Gigabyte boards in the past have put on substandard northbridge heatsinks. I've fixed it by either attaching a fan or changing the heatsink. That may or may not afflict their current lineup.
Gigabyte BIOS's are usually better than MSI. It depends on what you want to tweak. I know on one MSI I got, the BIOS was totally missing all the Speedstep and power saving modes so it ran full throttle all the time. I returned it and got the Gigabyte which had all that. Once again, YMMV.
ASUS boards are usually at the top of all the reviews on power consumption, which means they use more than their competition. As a home user, that actually sways me away from them. You may also get decent power consumption on boards where the manufacturers don't attempt to outperform the competition. You know....the boards there they are perfectly fine being in the middle or bottom of the pack. Biostar and ECS comes to mind.
