viperdv2k4
- Mar 7, 2005
viperdv2k4 said:The big water costs areound 125 so, any recomandations for a around $50 gpu block for a BFG 6800 Ultra OC?
Enigma422 said:-Maze4GPU with Acetal Top for GPU, RAM sinks optional, but recommended
that's quite a bit higher than his stated budget of $175.Enigma422 said:All in all this should come out to about $250.
DFI Daishi said:the bigwater is just not all that great a system, and you'd almost certainly get as good or better performance with nice air cooling.
you're comparing apples to oranges my friend.pigpen said:I keep seeing this in this forum. Where is it coming from? I have a big water. I promise you there is not an air solution (sans 15 case fans running at 600db) that will perform better. If you're talking about the XP-90 / XP-120, i've checked their results on a test system similar to my own (3.2E at 4.) I've yet to get my CPU past 55 at load.There's no way there's an air solution on the market that can compete with that.
DFI Daishi said:that's quite a bit higher than his stated budget of $175.
it will perform one heck of a lot better than the bigwater, it's just above budget.
on the plus side, those plastic cases are reasonably easy to cut into with a fine-tooth hand saw.
before i start suggesting things, i have to ask you viperd2k4, if you are much of a handy man. there are a tonne of ways to save money and have good performance, if you are willing to shop around at various local stores, and do some work yourself.
the bigwater is just not all that great a system, and you'd almost certainly get as good or better performance with nice air cooling. it would also cost less, and be a lot less work.
not kits in that price range.viperdv2k4 said:I dont think i could do any work myself, im not much of a handy man... Any suggestions or other kits?
DFI Daishi said:you're comparing apples to oranges my friend.
the xp 90 and xp 120 will keep an a64 just as cool as the bigwater, depending on the fan.(and i'm not just talking about 55db ear-killers)
with the little furnace that is the p4e, it's a bit of a different ball game.
they perform okay, but are above your stated budget, need a GPU waterblock and even if you do decide to run the rad outside of the case, you should probably still rig up some way of mounting it.viperdv2k4 said:how bout one of those swiftech kits at www.xoxide.com ? How do those perform?
you can keep an A64 cooler with a beefy watercooling solution than you can keep it with a nice thermalright. you can push the a64 overclock farther while maintaining a given tempertaure with a beefy watercooling solution. and you can often do either or both of those things more quietly with the watercooling, than with the heatsink. that is why people bother with water on an a64.pigpen said:That doesn't make sense though. If an A64 can be kept as cool with an XP-90 / 120 as it can with a better cooling solution (which i know the big water is from experience with my mini furnace), why would anyone with an A64 bother with water?
Point is, if you're planning on ramping that thing up and creating more heat, which i would imagine anybody looking into water is planning to do, the big water is better than any air solution. And last time i checked, those thermalrights can get pretty damn pricey.
I'm not defending the big water kit. like i said, there are probably a million better water solutions out there. but it is untrue that there is an air solution that would give better results.
TheLonelySwedish said:By the way Dashi, do you watercool?
i use thermoelectrics(peltiers), but the hot sides are cooled on water.TheLonelySwedish said:By the way Dashi, do you watercool?
i was thinking about pointing him this way, but he expressed doubt about being able to cut, wire and mount. he also seems to be indicating that he wants kit.2Fresh said:I sell rads bro, chaep and work great.
http://www.hardforum.com/showthread.php?t=874806
neither of the units that you just linked do all that well, since they both take and return air to the case.viperdv2k4 said:So, what do u recommend?
DFI Daishi said:neither of the units that you just linked do all that well, since they both take and return air to the case.
i know what kit i would reccomend if you had a bigger budget, i know what parts i would reccomend if you were game for doing some DIY.
dewhite linked a kit that he has found does decently well for somthing really basic to start out with, and is in your price range. you still need to work out how to mount everything, but that will pretty much always be an issue.
what am i supposed to say at this point?
