archivalbackup
- Oct 12, 2007
I need some help parsing some configs to make sure this will work from a VoIP standpoint. I have a client that has two private T1's between the central office, and an office out of state. They want to bond the T1's into a single multilink to get better bandwidth for some heavy hitting database traffic, but they have their PBX tied into one of the T1 cards and I am not sure how to go about doing this on a bonded link. Here is the relevant configuration on the T1 card that has some voice channels carved out:
The other T1 Card (currently in another router for redundancy) is just a straight up T1 card
The inventory display for the voice card:
It seems to me that everything is being sent VoIP between the two sites, but they think there is some reserved channel setup with the phone company. I lack the VoIP depth to be sure.
Code:
controller T1 0/1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/1/1
framing esf
clock source internal
linecode b8zs
ds0-group 0 timeslots 1-6 type e&m-wink-start
interface Serial0/1/0:0
bandwidth 1544
ip address x.x.x.x 255.255.255.252
ip directed-broadcast
ip nbar protocol-discovery
encapsulation ppp
ip tcp header-compression iphc-format
max-reserved-bandwidth 100
service-policy output PtP-Edge
ip rtp header-compression iphc-format
voice-port 0/1/1:0
dial-peer voice 200 voip
max-conn 7
destination-pattern 2...
session target ipv4: x.x.x.x
ip qos dscp cs3 signaling
dial-peer voice 100 pots
destination-pattern 3...
port 0/1/1:0
Code:
description Point-to-Point T1 link to
bandwidth 1544
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
service-module t1 clock source internal
service-module t1 timeslots 1-24
Code:
NAME: "Two port T1 voice interface daughtercard with Drop and Insert on Slot 0 SubSlot 1", DESCR: "Two port T1 voice interface daughtercard with Drop and Insert"
PID: VWIC-2MFT-T1-DI= , VID: 1.0, SN:
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16 , VID: NA , SN:
