Need a Videocard! budget $200
Hi, i need a video card to run the new Elder Scrolls game. I have a budget of $150-200. I preffer Nvidia. I need AGP card. I would rather spend ~$150 but if there is a way better card for just a little more then i will get that.
also is this computer going to be enough to run the game? Athlon 2800 and a 1gig of ram?
Thanks so much
save up, and get am2 when it comes out
its a bad time to build a pc now
I don't know anything about the game Elder Scrolls, how would something like a 9800Pro/XT run it? Those are dirt cheap now.
I have the same specs (a64 2800+ 1gb 3200) with a 6600gt and oblivion eats it up and spits it out. I have it set at medium textures and medium pretty much everything with hdr on and 2x AA, but have to have it at 800x600 to keep it somewhat smooth. I turn up the settings when I'm indoors because it's mostly the forests that the card struggles through. I still havent found the sweet spot for settings. I would try and find a used 6800gt or a 6800gs at least.
Not really. AM2 is 939 with DDR 2. Which is usually slower than DDR.
Your best deal is an unlocked 6800gt or x800xt (or unlockable VIVO / GTO2 -version pro) off the FS/FT forums.
-SEAL
