altec_tech
- Aug 17, 2004
Hi, I currently have 2 Dance Dance Revolution hard pads I had purchased off of Ebay.
I was hoping to connect them to my computer and playing, but they use VGA inputs. They are meant to be played on the PS2, because they come with a VGA to PS2 adapter. They work great on the PS2.
But I love playing my infinite library of songs, with a near infinite amount of options on the computer using the free app StepMania.
I purchased a PS2 to USB converter. And it worked out alright for the first time I played. But then the pads would randomly switch coding of wires I guess, not sure really. For instance, the up would become right, right would become nothing, the down would become up, and the left would become down. Makes no sense.
When I went to the key programming menu, I went to go reprogram the buttons on the pad. When I hit the up button it gave me something along the lines of button 52 or something. But then after playing for a few minutes, the up button would become like button 5 or something. I can't remember the exact thing, as I have not tried it again in awhile.
I am sure that the reason for this happening is that it is running through two different adapters. It goes from VGA to PS2 to USB. So I was hoping that I would be able to find something that could convert VGA directly to USB. I would prefer if the adapter had TWO ports, so that I could connect both my pads into the same thing, plus it might save some money.
I looked around for half an hour and couldn't find one thing that was called VGA to USB. I checked newegg and ebay, and no luck. Found a USB to VGA, but it was very expensive($60), and only had one port, so I'd have to buy two.
I paid $250 for both the pads (125 each) and I would hate for my investment to be wasted and paying for more than half the price of both the pads, JUST to hook them up to my computer.
Anyone have any ideas that might work?
P.S. the VGA wire that comes from the pad is a FEMALE connector. As it came with a MALE adapter to convert it to PS2.
Am I screwed?
Am I screwed?
