NathanP2007
- Dec 17, 2007
So my house currently has a D-Link DIR-655 Extreme N Gigabit Wireless Router, and we are loving it. However with the size of our house, the back of the house has a second story, and it gets no signal. Under that second story is a bedroom that has wired ethernet running through it. In the past we had our old Linksys Wireless router in that room, the ethernet plugged in and it was putting out a second LAN signal that gave the second story/back of the house a full signal connection. Long story short, the Linksys router sucked so bad we tossed it, and upstairs has had to use Wired since.
-Im looking to buy a wireless router now so the upstairs can get full signal again. Obviously considering our D-Link DIR-655 Extreme N Gigabit Wireless Router has been so awesome, iv been considering buying it. However considering its $60, i was curious if i should go with it, or are there any other options iv overlooked? A signal amplifier that the ethernet can plug into and amplifies the LAN signal (so i wont have to make a separate LAN?) If so, is there a most loved/bought model you can link?
If i do get the D-Link DIR-655 Extreme N Gigabit Wireless Router, do i have to create a separate LAN? or is there a way for it to use the same network/password? and lastly, if i get the DIR-655, will the two signals degrade each other? Or compliment each other?
