Need a SCSI /w Raid Card
askyrie
I need a SCSI /w raid controller card. I can only find Adaptec making these but there are so many models that I'm lost. Basically, I want a 320 capable SCSI card to set up a Raid 0. Can someone point me in the right direction here?
Can't do PCI-X btw.
Thanks
PCI-X is backwards compatible, so is U320, U160 ect
what PCI slot do you have?
32bit 33MHz
32bit 66MHz
64bit 66MHz
what is your stripe width going to be? (# of HDDs)
more than likely U320 is going to be sheer overkill
extra bandwidth you couldnt possibly touch with the apps you'd run
(or bandwidth your PCI slot wont even allow you to access)
U160 might be a much better choice for a RAID card
do you have other SCSI devices (CDR, Tape Drive?)
adaptecs main competition would be
LSI Logic U320
LSI Logic U160
Check eBay..
Plenty of Mylex AcceleRAID cards floating around for a good price. Not necessarily what you are looking for. They have LSI chipsets, btw. I'd stay away from Adaptec unless you had deep pockets or access to thei NFR program.
Ice Czar is right though, if you don't have 64bit PCI or PCI-X (which we have confirmed), you really won't be able to utilize the capabilities of the array. Ultra160 would be much better and less expensive. Then again, is it okay to ask why you want to do this?
it hardly takes anything to max out a 32\33 using a wide enough stripe :p
As the Disk Spins : Speed Matching
"Once the host transfer rate is lower than the effective internal transfer rate (e.g. because of a jammed I/O bus as shown in the illustration or else because the combined media performance of two or more drives in a RAID Level0 configuration exceeds the host transfer rate), the cache fills up and the data can no longer be transferred from the media to the cache because there is no capacity left. In that case, the head will have to skip reading e.g. LBA #1 (as shown above) but since it is necessary for all further transfers, the drive will have to wait one full rotational latency to "get back to business as usual". During this artificially imposed latency, the cache can be emptied by outputting the data to the system bus"
a 64\66 is another matter
