Need a Scanner with a document feeder
AchTuNG!
Hi all,
I'm looking for a medium volume scanner. when i say medium, I mean it will barely get used, but when it is used, it will need to scan multiple pages quite quickly. I have seen then around with document feeders, similar to bigger photocopiers.
I would also love the old style direct printer output so that I can connect direct to a printer lpt1 port for quick copying, and maybe connect to pc via usb.
Does anybody know what I should look at?
Dell has a new series of all in ones you may want to look at. I just picked up a 1600 n laser prnter copier scanner for under 400 dollars for my offfice, Color will cost you more but anyway take a look them on the Dell small businesss site
