Need a recomendation On a wireless keyboard
Pretty much like the title says. I'd like to not spend more than $50 but if its something cool than i might reconsider. Thanks.
I do not need anymore mice so im trying to avoid a keyboard mouse combo, but if its inevitable than its not a problem.
I don't know if you can find a wireless keyboard for $50 or less. Maybe check eBay.
I never got the reason for a wireless keyboard
A wireless mouse I can definitely see (tho it will lag sometimes) but a wireless keyboard is stationary!
I have a very long DVI cable hooked up to my living room LCD (52" toshiba regza) so i can sit on the couch away from the computer and still use a keyboard.
I've used the original Saitek keyboard and unless the Saitek II is like revolutionary in comparison then it's nothing to brag about. I've used quite a few different desktop keyboards and I've had a number of different brand laptops and I'll have to say that the MacBook Pro has the best feeling keyboard I've ever typed on by a large margin. After that I would say the Lenovo ThinkPad keyboards are pretty great as well. When it comes to a keyboard I'm all about style and feel and so I'm thinking about picking up one of the Apple Pro keyboards with their thin aluminum design. I'm guessing the Apple keyboards work fine without even installing a driver on Windows Vista don't they? MAC's run Windows through Boot Camp no problem.
http://www.apple.com/keyboard/
It's so that you don't have any loose wires on your desk which take up space and leave you with a less "clean" look. With a wireless keyboard you can also use it on your lap or something when you're sitting somewhere away from the computer such as in the living room with a media center PC.
