Need a Quick Answer
Ramaddil
I am trying to put additional storage in my computer that I just bought and I have used up all my regular sata ports however there is one more sata port that has sata_raid2 next to it. Is it possible to use this port as just a sata port and not a raid port?
You'll probably be just fine.
After all, you probably have a single non-RAID drives plugged into sata_raid1 and sata_raid0, right? :)
yes all my drives are non raided.... i can not get it to work thought i have tried a few different settings in the bios to no avail
What motherboard?
Definitely need to know this.
I've seen a few mobos (usually OEM stuff) that actually turn the extra ports off in the BIOS (for some bizarre reason). Usually you can turn them on though.
What do you mean it doesn't work? You cannot see the drives in Windows.. in Bios? there's nothing to turn on? details details details :)
From the manual you should set Silicon Image Mode [RAID Mode] to SATA2 Mode in onboard device configuration. Then make sure the Silicon 3132 Controller driver is installed in Windows and then setup the drive in Disk management.
