Need a quick answer please
shivang222
so i have the silverstone zeus 850w power supply and on a couple of the large wires coming right out of the psu there are multiple connections.. such as one wire has three connections on it.. so can i use only one of the three connections or can i use all of them silmultaneously?
Hello, I am not exactly sure what you mean. I think you are wondering if more than one device can be attached to the 4 pin molex or the SATA hard drive power connectors on a bundle of wires coming off the PSU at the same time. The answer to that is yes, if you have 3 connectors you can hook up 3 devices.
You may want to look at the included manual to see that you get the motherboard connectors attached correctly.
