Need a new cpu HSF pronto
NeoNemesis
I can't take it anymore, the stock intel fan on my cpu sounds like a jet engine so I can't sleep with my computer on. I just got my income tax back :rolleyes: so money isn't really an option. Keeping in mind that I'm planing on OC'ing this thing right after exams, what should I get as a replacement. I'm thinking the Zalman CNPS7000A-AlCu. Any other suggestions?
you could go water.
the zalman is not THAT great. although i do like it. if are to get one make sur it is the pure copper one not the alcu.
or you could get the sp-94 w/ a 92mm panaflo.
i would go water. it can be done cheap or expensive. all up to you.
also since " money isn't really an option" you could go to a mach system or any other phase change.
and if you are really crazy you could do a cascade sytem.
