Need a new Cable Modem
RKBET
I have a SB6120. My cat crewed the power cable. So I need a new cable modem. I know I can get another power cable off ebay. But I had this box for the longest when Docis 3.0 came out.
I heard rumors of Docis 3.1. I wonder if its okay to get the SB6190 or wait for the rumor SB8200 which is Docis 3.1. I want to be future proof til 2025 or something. Any ideas?
DOCSIS 3.1 is very new and I don't believe such end-user equipment is readily available. Even if you can find such equipment it'll probably be very expensive, and also probably suffer from first-generation issues and the bugs will need to be shaken out.
DOCSIS 3.0 will be viable for a number of years. The SB6190 should serve well, though I'd recommend considering the SB6183 as it's much cheaper (Costco often has good deals on it) and fully supports all but the very highest/priciest speed tiers.
Trying to future-proof for nearly ten years is foolish, though. Who knows how things will look then.
I'm aware of that. I just like having the latest hardware. I already have the 6190 in my amazon cart. I just wanted to know should go with it or wait for the new one. Comcast probably won't have support of it yet but I will never rent their stuff.
Go with the SB6190. DOCSIS 3.1 is still a ways out from mass adoption, and the DL/UL capabilities of the modem will likely far exceed anything most cable companies are willing to push through for several years.
Just to be on the safe side, check with your ISP to make sure what you're buying is on their compatibility list.
I might be the only person in the world who had a problem with an Arris/Motorola box, but as an alternative, I like my Linksys/Cisco DPC3008 cable-modem which replaced it. Never had a problem with it.
Sounds like you need a new cat.
He's outside when I'm not home.
The sb6190 is on their list
That is not high end for me. But it looks cool as the sb6190 is white and the DPC3008 is black.
