Need a new 80mm fan...
Z-Ro_da_Cr0oked
hi im new to the forums but anyways...
my vantec aeroflow crapped on me so i got a replacement.
aerocool phantom
http://www.newegg.com/app/ViewProductDesc.asp?description=35-183-102&depa=0
it keeps da cpu at 46c when it use to be cooler...
on the heatsink is the stock fan which is this
http://www.newegg.com/app/ViewProductDesc.asp?description=35-129-221&depa=0
(except fan is clear)
i think
i was wondering whats a good 80mm fan thats quiet like this one but pushes more air....
im hoping this will then make my cpu cooler...
thanks
i forgot to mention it must have blue led lights cause all my fans got it and i wanna keep da theme goin
in aida 32 it says the fan is runnin at 3000 rpm so i will need one thats faster then this with blue leds...
thanks
Coolermaster Blue led fan are pretty good.
But you must understand that with led fan you are sacrificing performance for beauty.
I had a red led fan on my HSF, the theme of my case was red led fan all over the place, but I changed it to a Panaflo because of the lack of performance.
I have a couple blue UV LED fans from SVC.com that are really nice (the LEDs are UV and make the fan glow blue). Otherwise you can also get fans with just plain blue LEDs from SVC.
im getting those but question....
when i put it on my cpu and plug it into mobo or do i plug it into that can controller?
also if i plug into mobo how will i control the fan speed?
Attach the temperature sensor to the back of your CPU. It will control the fan speed for you.
Get the smart fan blue if you want the temp control but the coolermaster one rocks but no temrmal sensor...
