Chellexelle
- Sep 8, 2014
LAST UPDATE
I have ordered all my parts including the motherboard so... case closed? NE Ways, thanks for all the advice.
NEW UPDATE
I have decided to got with the ASRock Z97 Extreme4/3.1. It comes in a BLUE color scheme and comes with a USB3.1 Type A/C add-in card.
UPDATE
So, I have narrowed down my choices to these boards.
ASRock Z97 Extreme9
Gigabyte GA-Z87X-UD3H
Gigabyte GA-Z87X-D3H
MSI Z97S SLI PLUS
MSI Z87-G55
Or the ASUS P9X79 LE if I go with i7-5820K
What do you guys recommend?
Gaming (The Witcher 3, Cities: Skylines, War For The Overworld), eventually I will be doing A\V production.
Up to $400 for the motherboard but would prefer not to spend that much, Tax? No
3) Which country do you live in?
US, Washington
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
Motherboard
What I have:
INWIN Tou
Kingston HyperX FURY 4GBx2 DDR3 1,600 MHz UDIMM 240
Toshiba 5TB HDDx2 - PH3500U-1I72
What I have picked out to order:
Samsung 850 PRO 256 GB Internal SSD
eVGA SuperNOVA 1000 G1 Power supply
Intel Core i7 I7-4790K 4 GHz - LGA1150 Socket
Creative Sound Blaster Zx
ZALMAN CNPS9500A-LED 92mm 2 Ball CPU Cooler
5) If reusing any parts, what parts will you be reusing?
CD\DVD drive for old PC.
Seagate 4TB HDDx2 - ST4000DM000
6) Will you be overclocking?
No
Samsung SmartTV 1080p, 55"
ASAP
9) What features do you need in a motherboard?
Intel. Crossfire and SLI support, haven't decide on ATI or Nvidia. USB 3.0. SATA 10Gb/s... or whatever is fastest for my SATA drives. I don't know what UEFI is. Enough PCIe slots for two graphics cards, a sound card, SSD, and whatever I may need for A\V production.
Update: ATX, BLUE color scheme, it's more important then I thought and in case you haven't noticed, I like BLUE
10) Do you already have a legit and reusable/transferable OS key/license?
Windows 8.1, 64bit. Planning to upgrade to Windows 10
Updated 2, 4, 5 and 9.
I don't want to use ASUS because there are too many bad reviews on their boards being DOA or lasting only a few months and those reviews say that ASUS has terrible customer service, long RMA return times and a tendency to send customers back the same damaged board.
Grr..
I still don't know which board to choose. Different people will have different things to say about one board maker then another. It seems ASUS has the largest market share and more people use them so I guess I am going to just have to roll the dice and hope I don't get a broken board and have to go through some horrible RMA experience. ASUS is back on the table.
I found the EVGA Z97 Classified which looks like it would be perfect if it came in a blue color scheme.
NEW UPDATE
UPDATE
ASRock Z97 Extreme9
MSI Z97S SLI PLUS
MSI Z87-G55
US, Washington
Motherboard
What I have:
INWIN Tou
No
ASAP
Grr..
