Need a mobo for my E6300
PaintballBrokeMe
I recently picked up a E6300 for really cheap. Now I need to get a motherboard. It needs to be cheap but performs decent. Any help is great. Thanks
Budget = Under 100.
i've got a cheapo ECS mobo that I'll sell ya. It uses AGP and DDR2 or DDR1
945 chipset does not overclock as well as 965; if you want spend 20$ more for the gigabyte s3 - i would do it, if not that is your best bet
its not possible for you to save 15 more dollars and get a gigabyte p965-s3? its usually not worth it to skimp below a certain point...
i've got the gigabyte 965p-s-3 . it's a very good mb for the $116 . i have mine overclocked to 480fsb with a 6300.
the biostar may also be a good mb although i haven't tried one myself . i suppose it would be my second choise if i absolutely couldn't scrape up the extra $10 to get the gigabyte .
and there is the foxconn 965p it runs $99 and has some overclocking features but so far lacks cpu multi options . it should still overclock some with a 6300 or 6400cpu .
the main thing with these 965p mb is having good ram that can take the high fsb .
for the 6300 though i would get the gigabyte s-3. it is nearly the same mb as the ds-3 - minus the solid caps.
With that cheap board you don't give yourself the option to overclock later on, not to mention the perfomance hit you take on it.
Not doing a least a mild overclock of a e6300 is a waste imo, you can stretch maybe another 1-2 years out of that processor performance wise for like $37 extra.
SAVE!!! the $37 extra seriously, no one hear will back your decision to get that 945 board.
Don't forget that the 945P chipset only uses DDR2 533 and 667. It won't take advantage of DDR2 800's extra performance. Additionally it's limited to 4GB of ram, and doesn't overclock as well.
http://indigo.intel.com/compare_cpu/showchart.aspx?mmID=22754,143,8764&familyID=10&culture=en-US
The 4GB limit of the chipset isn't a huge deal, but its just another reason why the P965 Express chipset is far superior. Plus the P965 Express chipset also uses the newer ICH8/ICH8R south bridge instead of the older ICH7/ICH7R south bridge. (Not a huge difference either.)
