Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a Toshiba Satellite laptop with Windows Vista operating system. Trying to add space without having to delete programs. How do I do this???? Wondering if maybe I need an extra C drive.
You could replace the internal hard drive with a larger capacity drive and transfer, or you could use an external hard drive as a supplementary drive. An external hard drive plugs in like a flash drive (via usb) and you can easily get a 1TB capacity drive from newegg for about $90. The external hard drive is an easy and inexpensive solution.
$58 - WD Scorpio Blue WD5000BEVT 500GB 5400 RPM 8MB Cache 2.5" SATA 3.0Gb/s
You can google for instructions on replacing the drive for your model laptop if you don't know how. You can use a drive image program to clone your current drive to your new drive (WD offers a free limited functionality version of Acronis True Image on their website).
