I just finished putting together my first pc and it came together quite nicely. Everything worked fine and I was able to get to the Bios screen, but now I am stuck. I have enabled the raid option in the bios because I want to set up my 2 seagates in a raid-o config.
I do not know what to do from here. I will be using Vista as my OC and my question (although probably rather dumb) is this. Do I now go ahead and put in the vista CD and begin installing vista? The only reason I am hesitant to do this is because I have heard that I will need a floppy drive with the raid drivers on there to insert when vista prompts me to. Now what I have tried is booting up the comp with the mobo support disk inserted (I am using a ASUS p5n32 680 mobo btw). What came up was an option to create floppy disk containing raid drivers for either 32 or 64 bit windows 2000/XP, there was no option for Vista. When I went to insert my disk, my computer spat out an error saying it could not read the A drive... My first question is why is this happening? My second is, once I am able to get the FDD working, will creating a floppy disk with the XP raid drivers work?
If my steps are correct I will need to create this floppy disk, and then insert vista and begin to install, that way I can insert the floppy with the drivers when they are needed. Now I have also heard that Vista can retrieve the drivers from a disk which would alleviate my problems completely. Does anybody know if this is true? And if so, is that just a matter of taking out the vista disk and putting in the mobo cd?
any and all help is very much appreciated, thanks a lot
