Need a little help
ScratchDrive
Ok, my current setup is:
Asus A8N-SLi Deluxe
AMD Athlon 64 Venice 3200+ 2.0GHz
1GB Kingstons HyperX PC3200
XFX GeForce 7800GT PCI-e
Western Digital 160GIG Sata HD
Sound Blaster Audigy Gamer
Ok well I was under the impression from reading all the reviews about everything in my PC that it would run BF2 on maxed settings well it does but Ill get little FPS lag spikes here and there not a big deal. Everytime I quit BF2 though I get 2 Critical stop sounds. One after the other very quick, but no messages pop up. And in my Event Viewer there is nothing. Can someone help me out with this and also does anyone know if my PC really should run BF2 on maxed SMOOTH or do I need another GB of ram to make it REALLY smooth. Thanks in advance.
