need a little help with new build
txmale4969
All of the above; it's a general purpose machine with a heavy lean towards PC gaming, specifically MMORPGs.
Bang for the buck within an unlimited budget but just because I can spend it doesn't mean I want to.
3) Where do you live?
houston texas
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
PSU, CPU, MOBO, Case
not reusing other parts other then gigabyte 460gtx
6) Will you be overclocking?
I'll be dabbling to see what I can get but it's not a focus of the machine.
i have 20.1 dell monitor now.......want to get bigger one down the road.
next week when i get my tax return money
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
i want to raid the os with data is all. so im thinking two wd cavier blacks in raid 1
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
i would need windows 7 pro 64 bit with this build.
i want to try one of the new asus matx boards. just not sure on which case. thinking silverstone or lian li.
any help appreciated thanks.
was going to do sb build .......now on hold. mods can delete or lock thread.
