Ok, first off I have this Hewlett Packard Pavillion that I use to browse the internet.
The problem is that well....it's a piece of shit. It's slow, buggy, crashes for no apparent reason, restarts for no apparent reason. And it's got way too much useless shit on it from the factory.
Here's what I want to do. Mod the crap out of it and basically redo it. But, I'm short on funds and I'm not looking to do anything really fancy with it. I just want to basically make it so that I can surf the net and be happy with it.
How do I go about identifying the internal components, you know, mother board make model, processor (well this one is kind of easy), video card, card readers...things of this nature?
Then once I identify each part how do I decide what's worth keeping and what isn't?
I am going to change the case as well, well not put the guts into a new case but I'm going to change the way the case looks, add a window, some fans. Stuff like that. Overall the case isn't bad loking, the CD drives are already stealthed somewhat. But it does have HP all over it which I'm going to get rid of.
I'll get some pics up of it so you can get a better feel for what I'm talking about. I'll show you how cluttered it is inside. And hopefully you can all come up with ideas to help me out with this.
Thanks.
Thanks.
