Need a HSF Recommendation
Right now I'm doing some upgrades to my computer, and next up is the cooling. I'm using a stock HSF, and it is terrible. I want to find a new one, but I don't know much about them. I'm not looking for a huge $60 enthusiast HSF, but something that will keep my non-overclocked a64 3200 below 40C idle...
I would pick a Zalman, but I don't think they are compatible with my mobo (an MSI RS480M2/RX480M2 (MS-7093)).
Any suggestions? Price isn’t a big issue, but like I said, nothing really over 30-40, and less is better. Thanks in advance!
EDIT: I also have some nexus fans on hand, all sizes, so I'll probably use one of those on the heatsink, but if the HSF are attached permanently, that’s fine too.
Zeppelin_Child said:
That looks pretty good, I'm worried about it fitting in my case though?
You should be fine if you just have something like a mid tower or whatever.
Are there any cheaper solutions? Well I'm sure there are, btu is this pretty high up as far as price/preformance ratio goes?
