Need a heatsink
Granthos
well i am thinking about getting a VC for my third moniter i am going to get, and i decided that this is what i wanted, idk if the fan is going to be loud, but if it is i was wondering, what is a cheap heatsink that i can put on this, i don not think that it will get that hot, but i need one that could fit on it
It wouldnt suprise me one bit if that would run fine without the fan in itself. Since its an FX im going to assume you wont be gaming with it, so it wont be stressed too much, I would try running passive first before you buy something. I have an old mx 440 with a passive sink (no bigger than a northbridge heatsink) and it actually overclocks 100+mhz still with no fan.
ok well i might even jsut under clock it, all it is goign to do is run a 19" moniter, shouldnt put that much stress on it, and if it does i will go out and buy a northbridge cooler.
and do you think i would be fine with a low profile MX4000 since i am not gaming? Just looked tho, and it does not have DVi, which i want so this is what i think i will get thanks for your help
