Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
My sitecom router stops working after some time everyday. It is 2 months old and just yesterday started to have this problem. So yeah I need an excellent router. Max I can pay is 150$.
Get a TP-Link TL-WDR3600 at Microcenter or Newegg and install OpenWRT (with LuCI if you want a webif) on it. Done ;-)
I'd say its a better choice than the Asus given the Ralink radio issues with Asus routers.
If you want more standalone-ish router I'd say Ubnt EdgeRouter Lite coupled with a 16Gb USB memory running FreeBSD and the TP-Link as AP.
//Danne
I like TP-Link for home stuff. I am running a TP-Link Wireless N access point and it has 4x vlan based SSD capabilities. I love having my Guest/etc.. VLANs all split up wirelessly using my Cisco router as DHCP server doling out address pools for each VLAN. I have a true guest network zone setup that truly segregates it from other vlans. Not bad for a $39.99 AP from Microcenter.
I am really hopeful that TP-Link makes a Wifi AC AP the same multi-ssid vlan based tech.
i just posted this yesterday....if you don't mind learning new stuff, one of these would be far better than pretty much any other off-the-shelf router out there
my company uses the non-gigabit version of this router for commercial wifi hotspots on military bases across the world....really excellent devices
