A few months ago, due to a slight leak, my old Hydor L30 overheated and died. Since I needed my computer back faster than I could mail-order a new pump, I found a decent pump at the local Lowes, and stuck it in my homemade external WC unit. It wasn't all bad, as the new pump has "Thermal protection" which means that it would shut itself off before burning itself up. (Which was OK, because I set up my BIOS to shut down the system at 55C, and the systems would just shut off if the pump shut down.) However, the new pump has a couple of drawbacks: It is annoyingly loud, and it really doesn't appear to be putting out much flow, even though it claims to be rated at 330gal/hour. (I'm using 1/2" tubing, FWIW)
I'd like to replace it with a new pump that has the thermal protection, and is relatively quiet and powerful. Additionally, I use it in an in-line (non-submerged) application, so it needs to be able to handle that without overheating.
FYI - I don't need a "silent" pump. My hydor was fine, if they had thermal protection, I would buy another one. The new pump can be heard easily from 30-40 feet away. I need something that is tolerable from 4-5 feet away.
Suggestions?
Suggestions?
