Need a good mATX power supply
draksia
I need a good mATX power supply that will fit with in a 4.5"(116mm) length. So far I am not having great look find one, newegg only seems to have Athena's or FSP's.
Also quiet is a important factor.
Any suggestions would be helpful.
Thanks
edited: I need a short ATX psu.
Thanks I do appriciate the suggestions but both of those seem too small. Those are 5.1x4.9x2.5 amd 4.9x3.9x3.0.
I guess what I need is a standard end plate sized PSU but shorter 4.5" then the standard 5.5" plus ones. Something that is roughly 5.9x3.5x4.5.
Okay, so you're not looking for a microATX PSU, you're looking for a short ATX PSU.
Yeah, It is going in an mATX so I guess I assumed it was a mATX psu which it is not.
So I need a good short ATX psu.
Well how much wattage do you need? How do we recommend one without this detail?
It is 8200 based AMD board with a stock clocked X2 550 BE. Just the intergrated video.
So I am thinking about 400w or so should be plenty.
I use a Seasonic 300W 80+ efficient power supply on my rig with a 95W TDP Athlon 64 and a dedicated videocard (Nvidia 7600GS) on my media center machine 24/7 without any problems. I'm too lazy to check the dimensions but it was very very small. If it works on my parts it'll work on your. Also keep in mind you can order a MATX PSU, and use an adapting bracket to make it fir a case made for typical ATX supplies.
I measured and I think I can cram the standard 5.5 depth PSU in there. So I ordered a Seasonic unit, the S12II 430 that should give plenty of headroom.
