tehslippery
- Feb 17, 2012
Like the topic says, I'm looking for a good computer chair. I currently have one of those $150ish ones from like Office Max. While it has worked fine, it's about 2 years old now and quite frankly just beat up. One of the arms had the screws that hold it in place broken and it just wobbles, the hydraulics are iffy at best and generally the chair just sinks.
I need something fairly heavy duty. I work from home, so I'm generally going to be in the chair 12-16 hours every day. Something comfortable that can last under that kind of use. I'm a bigger guy (~230lbs) so it has to be able to work with that as well.
Budget would be around $500, but I have some wiggle room. I'd prefer not to spend that much, but will if the value is there for something that is going to hold up under my use and last.
Greatly appreciate any suggestions!
