Need a good black & white printer
zman099
What do you guys suggest is a good black and white printer for under 100 dollars thanks.
In my opinion a laser printer is the best choice in the long run. It will end up costing you less as the toner will last a lot longer then an ink cartridge on a ink jet printer. HP has mono laser printers for as little as $119, and you may find a used printer for under $100 on ebay.
get a basic Hp laserjet - either new or used. should be about 100$ish
old ones are awesome, they do'nt die. new cheap ones are so/so
avoid samsung, brother, and lexmark - their cheap lasers tend to die after several tonner changes
