need a few suggestions for a build
The pc will be used for browsing, some gaming, and light photo editing.
My budget is $180 and actually only need a suggestion for cpu and ram. I've already got a socket 775 mobo. I live in maryland. I will be doing a little overclocking to get the most out of the cpu. I have a 20" 1600x1200 monitor. I plan on buying the parts very soon. I already have a retail copy of windows 7.
And the second question is for a suggestion on a video card which will be going into a second computer. I'm currently on a c2d q6600 8GB Ram with a 8800gt. My resolution maxes out at 1680 x 1050 and would just like a bang for your buck card that will play anything i run on it maxed out.
What's the budget for the vidcard?
LGA775 mobo... which chipset is it and what type of RAM does it take?
are you near a microcenter?
