Need a driver... Can't find manufacturers website.
Mandane
Yes, I bought a computer and the manufacturer I bought it from is "emax".
Well, I having trouble finding their website.
Does anybody know where their website is?
Thanks,
Mandane
P.S.- If it helps, I am looking for a driver for my Intel PRO/Wireless 2100 Network Connection. Just wondering. I tried searching for their website, but was unable to find it...
D3v1an7
If it was me, I would open the case and get the model number off the NIC and search for that (assuming it is not onboard)
Couple of questions:
What OS are you using?
Why do you need to update the driver?
Monkey34
I found a number of hits on google for "Intel PRO/Wireless 2100 Network Connection driver". To be sure tho, open the case, and get the numbers right off of it first.
Mandane
Well, I'm running on WINDOWS XP.
The reason I am trying to update the driver is because I am having trouble with a stupid patch I installed on my computer (Q815485 ).
I need to update it because this patch is somehow interfering with my wireless connection. I'm following the instructions given by Intel .
svet-am
Well, you know it's an intel card, so that narrows things quite a bit. Like the other folks said, crack the case and jot down the exact model# and then hit Intel's site. They have a really good model# search feature.
