Need a double check here....
SDNYC09
Take a look at my system...im feeling the temps for the cpu are off, my house is usually anywhere form 24c to 28c...
temps in core temp idle 37-40 ... and load 53c-57...
running stock speed on an i7 975 for now till i get this worked out...
3333
1.2 volt
applied thermal paste 4 different times to check the lap
Loop
Pump ->Triple rad->cpu->single rad->videocard-.chipset->Res-Pump
Im using 85cfm 120mm fans for the triple rad which is thicker then a regular triple..its the Black Ice GTX Xtreme 360 Radiator..
these are the components in the water loop if you cant see
Swiftech pump 655-b
EK supreme copper block
swiftech single rad
EK 5970 block
EK chipset block - Gigabyte UD5
EK res plexi with flow meter
I figured this should be running very low 30's and mid 40's load...someone please correct me...
any help would be great...
