Need a CRT for gaming
impuLsive
I need a CRT that will support 1280x1024 @ 100mhz. This is for gaming. Any suggestions? If not, suggest a good LCD (2ms response time) for me.
FP2141Sb over at newegg
Mitsubishi DiamondPro 2070SB
NEC FP2141SB
Sony G520k
Sony FW900
A cheaper one, the NEC FE2111 can do what you want it to, but the above models are some of the best ever made.
Because one of my lan party buddies has one...he would have returned it if it did.
NEC FP2141SB
Sony G520k
Sony FW900
Don't forget the HP 7217A :D
You're going to get tearing if your video card's FPS is faster than the monitor's refresh rate, so he probably had V.sync on.
Depends on what the refresh rate on his LCD was also.
