Need a CPU/MOBO/RAM/PSU/GPU for $300ish
Volkswagen
Hi All,
My cousins PSU went in his S939 PC and he wanted to do a small upgrade and I told him that I could build something decent for arround $300ish if we get a new cpu/mobo/ram/psu and if possible a new GPU ( currently he has a ATI X850XT PCI Express ).......
1) What will you be doing with this PC? Web Browsing, Music and light Gaming
2) What's your budget? $300-350 with tax and shipping included
3) Where do you live? NY
4) What exact parts do you need for that budget? CPU,MOBO,PSU,RAM and GPU if possible
5) If reusing any parts, what parts will you be reusing? 74 GB WD Raptor, Sony DVD Burner, Coolermaster ATX case and possibly an ATI X850XT PCI Express GPU
6) Will you be overclocking? Probably not at the moment
7) What size monitor do you have and/or plan to have? 19" LCD
8) When do you plan on building/buying the PC? As soon as possible
9) What features do you need in a motherboard? Just something basic that will work at stock speeds- don't need raid/sli/firewire etc....
10) Do you already have a legit and reusable/transferable OS key/license? Win XP Pro
Here is what I have in mind already
CORSAIR CMPSU-400CX 400W $50 at newegg
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) $52 at newegg
I haven't kept up with the AMD stuff but I know that they are always great for Budget builds so I wanted to see what you guys recommend- want a dual core at least.
Thanks in Advance!
Should I just get a tripple chanel kit of DRR3 ram like you do for the intels or?
The first option might be the way to go minus the GPU as onboard seems to be decent and after we sell of the old S939 stuff we can try go get a better GPU.......
amd only supports dual channel memory, if you can get some friends to buy them together and buy 2 triple channel kits to share about yourselves. Cause would be $50ish for 2* 2 gig
Awesome- thanks for clearing that up as I was confused with the 3 white/blue ram slots on the motherboard :)
Since I will skip the GPU is there a better CPU that I can get with the $70 I will be saving?
