Nicepants42
- Aug 30, 2004
I've got a problem where the Lian Li EX-23B will not fit into my Silverstone TJ07 for at least 3 reasons. (Front bezel too wide, front bezel protrudes out the front of the case ~.25" when installed, HDD's protrude too far into the case).
My situation is that I've got two free 5.25" bays that I need to fit (at least) 2 HDDs into, without the drives protruding much more than 170mm (from the front) into the case.
What I'm looking for (ideally) is a bay device identical to the Lian Li 23B, only able to fit non-Lian Li cases properly, and as compact as possible. Failing that, I'm looking for a standard 5.25" bay HDD enclosure that is quiet and as compact as possible.
Thanks for any help.
