Need a budget laptop
LateraLex
Office applications, printing/scanning. Looking for a laptop!
$400-500 would be ideal...
Boston, MA
Want everything including Windows 7 (no Windows 8 please). Would be nice to have an optical drive of some sort.
None
6) Will you be overclocking?
No
None
Within the next 2-4 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
N/A
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No
Thanks for the recommendation. I was hoping for an i3 and a decent screen size, so this could fit the bill.
Only downside is the 9 day build time... oof!
Any other suggestions? I might just grab something off of Amazon to make sure she doesn't have to wait 2-3 weeks :c/
I would buy almost any system for that price range. My own preference is for Asus in that price range. I'd buy an i3 but otherwise, the model would depend on the screen size. I really like the small ones since they are much easier to carry.
I'd consider a Best Buy sale or other local but nationwide store chain. It makes returns faster.
Would you consider a Dell Outlet machine? They're running some coupons through the end of the month.
http://www.dell.com/learn/us/en/28/campaigns/dell_outlet_business_sale
On the business side of things I found this Latitude E5430 for example:
Business class build quality and reliability, upgraded display and SSD (could also swap the DVD for another HDD later)
$486.75 ($649 - 162.25 w/25% Coupon VS18$N5BQQ7Z1W)
Processor: Intel Core 3rd Generation i5-3380M Processor (2.9GHz, 3M cache)
Operating System Windows 7 Professional
Hard Disk Drive 128 GB Solid State Drive
Memory 4GB (2X2GB) 2 DIMM DDR3L 1600Mhz
Laptop Screen 14.0 Inch HD+ (1600x900) Anti-Glare WLED-backlit
Media Bay 8X DVD +/- RW Drive
Video Intel Integrated Video
Base Dell Outlet Latitude E5430 Laptop
Network Interface Card Dell Wireless 1504 802.11b/g/n Half Mini Card
Web Camera Light Sensitive Webcam and Noise Cancelling Digital Array Mic
Laptop Battery 6-Cell (60WH) Primary Lithium Ion Battery, (2.8Ah) ExpressCharge Capable
