killerz298
- Sep 22, 2006
So I finally decided to build a new rig. I settled on the i5 2500k which I plan to gently OC and am now trying to find a suitable Z68 mobo. If I buy a combo at Microcenter, I can get the 2500k and Gigabyte GA-Z68X-UD3H-B3 for $300. If I buy the chip alone it is $180 plus whatever Mobo I get. Technically I would be spending $120 on this mobo with the deal. Is that too much or too little for basic use? I will be using a SSD drive and most likely only 1 SATA storage drive, 1 blu-ray drive, 8gb 1600MHz 9-9-9-24 ram, I have 6.1 surround speakers, and I don't plan to SLI/crossfire. What mobos do you guys recommend for my use?
