Need a 4 bay storage enclosure
tnt3k
I'm new to these NAS and stuff like that but i just need a external enclosure that holds 4 drives. Doesn't have to be over the network. Just something so i can clear all the external enclosures from my desk. I was looking at DROBO and the video advertisement kinda marketed it as really good. Are there any other good options around 300 or less?
Thanks
You'll need a controller with an external SAS port for that (or 4 eSATA). I would get the 5 bay version that uses a port multiplier instead.
why would i need this? doesn't the enclosure come with everything?
You get just the enclosure in at least that model. Given the available connections, how else would you plug it into your computer? A SFF-8088 connector isn't something that's normally found on a desktop (though as mentioned, if you have 4 eSATA, it will work with the right cable). I would also skip the Drobo as it isn't very good. This is a better option: http://www.newegg.com/Product/Product.aspx?Item=N82E16816111136
anything with USB cuz my laptop doesn't have eSATA =(
Stay far away from them. Do a search here for the word drobo. You will not get many good words about them..
There is a USB one: http://www.newegg.com/Product/Product.aspx?Item=N82E16816111047
I recommend spending a little more and getting the USB 3.0/eSATA combo one though: http://www.newegg.com/Product/Product.aspx?Item=N82E16816111149
Obviously there are other options as well.
Ya OP, do NOT limit yourself to a USB only unit. Getting a combo USB/eSATA unit will increase it's usefulness because eventually you will have eSata and will insist on using it when you compare the speeds to USB.
yuuup! Is there a hard drive size limitation for this unit?
Thanks for the newegg link. Gonna buy the sans digital. it fits right in my budget and works with what i need. Thanks for all the help!
I agree with SirMaster's suggestion of the DS410J, but if you must spend less and don't need ethernet connectivity, consider the Lian Li EX-50 along with those Sans Digital units.
