Need 939/AGP mobo recommendation
noworries
I've got a buddy who needs to replace his motherboard. He's got a Chaintech S1689 with an A64 3000+ and a 7800 GS AGP. He wanted an upgrade but was on a tight budget, so I recommended the FX-55 w/ free SATA2 HD deal from newegg for $199. The fx-55 wouldn't work in the chaintech without a bios flash, and then it started acting weird--so he want's to replace it. (it doesn't appear there's a way to flash that chaintech mobo without a floppy--and he can't make that work and we're on different coasts so I can't help)
So the new mobo needs to work with the new fx-55, and his AGP video card.
The best mobo I could find, that was in stock and under $100, was the Gigabyte GA-K8NSC-939 mobo. It's at ewiz and zzf for $60-$70. Any other ideas? Would prefer an abit or asus, but couldn't find anybody reputable with them in stock.
Any ideas/recommendations (besides telling him to go PCI-E--no budget for that)
The only problem is it's out of stock! It seemed every mobo I found that would work was either OOS or refurb between newegg and mwave. Thanks for the reply!
The Epox 9NDA3+ is a very good, estable and solid rock motherboard.
I have this motherboard and don't have any againts this epox product, I'm very happy with mine.
i too had this board before i upgraded to pci-e, even though i gave it to my friend, its a very good board, probably the best ive ever had, it does over 300htt easily and comes with many features ;)
How bout the ASRock 939Dual-VSTA. It has both AGP and PCIE. I just upgraded to this board on my son's rig. AGP performance is quite good. Here's the link.
The Gigabyte 939 agp mb with the Uli chipset is great. I used in my my daughter's computer with a 3800x2 cpu and an agp X800XT. Works real well.
