If I want to run 8gb of RAM, would it be faster to run 4x2gb of DDR3-1600-C7, or 2x4gb of DDR3-1600-C8 for the same price?
Would the smaller 2gb sticks with lower latency be faster even if I am using 4 of them? (2 of the 2x2gb kits)
Example would be 2 of the following 2x2gb CL7 kits for a total of 8GB for $130:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231430
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231321
Versus a single 2x4gb CL8 kit for $130
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
Both setups are the same price, but one is CL7 and one is CL8.
Does running 4 sticks of RAM have any negative impact on performance or latency allowed? This will be on a P8P67 motherboard. Thanks for the help.
