need 4x 150gb raptor RAID 0+1 setup tips
JumpingJackson
I recently got my hands on 4x 150gb 150GB WD Raptors on the cheap. Im going to be using the ICH10R on my P6T Deluxe x58. Was planning on using RAID 0+1
I am currently using an old 74gb raptor as my vista64 system drive and have a 200gb wd drive as my data.
I was planning on enabling the onboard extra SAS controller and installing the drivers for it, move my currently system drive onto it, then enable the RAID mode on the ICH10R and then get the drivers installed for it and then use a drive imaging utility to copy my data onto the new 0+1 array.
I havent set up a RAID array in a while, what would be the optimal settings to use for performance to set it up? Strip size? block size? What imaging software will work? Spare no details! :)
I was reading about the Intel Matrix Raid stuff, seems like a better route to go for 4 drives. How would you guys set it up? Short stroke like 120gb in raid 0 and the rest in raid 10 or 5?
If you try to do Matrix RAID, you will get a very small drive out of your drives. Take around 20% from your total of 600GB is what you are getting from the RAID's ultra fast space.
Actually i found out on ebay i can sell these 150gb raptors for like $120. I think im just going to get 2x 300gb velociraptors
