Need 3 PSU's
diablo111
I looked through the stickies and couldn't quite find the answer I needed. I am building 3 systems:
3GHz P4 (probably socket775, AGP and NO overclocking)
1GB PC3200
AGP nvidia 6600 (non GT)
(1) 120GB SATA HDD
CD-RW
Floppy
(2) 80MM Case Fans
The budget on the PSU is $45 (MAX) shipped...I'm thinking a good 350w should be able to handle it...which seems better than getting a cheap PSU at a higher wattage. Using Takaman's the total output is about 275 watts...with about 15A on the 12v rail.
I know I should be able to find a PSU in the stickies...but it's all kind of overwhelming. Any suggestions would be appreciated.
Since those are clearance items they may run out, also look at directron's selection of Superflowers. I say they may run out because I just ordered a pair, and at that price.... Thanks MaMMa
Yeah, I was thinking about Super Flower...I've been really happy with the ones I have used. A local store (local being 20 miles away) has Super Flower Case/450w PSU combos...I might just go with them...
