Need 3 Good 37" Displays
SensaiUN1
I am in need of 3 good 37" (At least) displays for work. The only thing they will be used for is being connected to a PC to display information about our data center. Needs to have at least VGA (DVI would be a plus) and must look at least half way decent being displayed through a PC.
Should I be looking at just monitors or could it be possible to use a TV. If I did go for a TV and went over it's native resolution how bad would it degrade the quality? Also trying to keep it under 800 per display. If there is anymore info that would help I can post it.
Thanks
as anything made for use as a PC monitor/public info display will be terribly expensive (although the panels are the same as the ones used in TVs, with the sole choices of 1366x768 or 1920x1080 as resolution) and the work doesn't sound like it would require great picture quality just look for the cheapest LCD TVs you can find and look up if they are listed to be capable of being used properly as a monitor without overscan:
http://pixelmapping.wikispaces.com/
