- Apr 11, 2003
Some of a discussion I'm having with a guy about a mobo that wont work:
ME:I wonder what would happen if I jumpered the "computer on" wires on the PSU while its plugged in to the mobo - if it would force a start..........I dont even know if I'm willing to try something like that.
HIM:Are you talking about setting everything up outside of the case and shorting the power switch pins on the motherboard? That works, and how I usually test motherboards.
I usually set them on top of the box and plug in the PSU, one stick of ram, the CPU and a video card. Then I take a screwdriver with a plastic handle and touch the two pins for the power switch. It will short it and power the board on. That rules out anything that might be grounding the motherboard improperly, and saves the hassle of getting it into the case to find it doesn't work.
ME:No, I tried that already - eliminating the case and switch as the problem. What I mean is hooking the mobo up(in or out of the case), with the psu plugged in, and with it plugged in - and short the wires at the psu plug - forcing a "on" signal. Normally, if you do this with the psu disconnected - it still will turn on........I've done it to run fans or test voltages. I'm wondering if it would jumpstart the board. I dont think it would hurt....it would only send power to the same places it normally would.
HIM:Uhm... I can't speak for what that would do, really. Just be careful doing it, thats for sure.
I've already tried clearing cmos pin, pulling battery, using different good parts, etc. I'm just wondering about this idea. I really want to use this board if at all possible. It started up for about 2 sec (fans on) and gave a boot error, and then shut down. It wont do anything at all now except I can feel the southbridge get warm with the psu hooked up.
