NEC's 20WMGX2 Replacement
the_real_7
looking for a NEC's 20WMGX2 Replacement mine still works great and id hate to part wit it , but is there anything gaming and color wise in 24 or 30 that competes with it that has the same specs ? I was looking at the 24-inch Apple LED Cinema Display but it needs some mini display port adapter is there any other choices that are ips screens?
The closest thing would be the NEC EA231WMi. IPS, standard gamut, low input lag, good responsiveness. Not glossy, but many users say the matte coating is somewhat smooth. No remote but one can live without it. Also doesn't have analog inputs if that matters to you. The stand pivots and height adjusts so that's nice. All in all, I would say that it's an upgrade in size only since PQ and performance should be roughly the same.
hmmm NEC EA231WMi like how simple the frame looks let me go look at some reviews but in the mean time back to 1680 x 1050 , lcd technology is so slow
I just ordered the ea231wmi. I also have a 20wmgx2 but I havent used it in along time. I loaned it to a friend. The 20wmgx2 is a great monitor for sure. I really like the glossy panel.
