I just returned an Eizo EV2336 due to terrible uniformity and severe backlight leakage. In exchange I purchased the NEC P232W. The P232W is 100% better out of the box, with no backlight leakage and good uniformity even with uniformity control turned off. The only problem I am having with the NEC is when I attempt software calibration with my i1 Display 2 colorimeter. With the P232W in 'Full' preset mode, I try to adjust the RGB channels in the six axis OSD menu, but the RGB doesn't budge. I can adjust luminance, but not RGB. I understand that the i1 Display 2 is not reliable with W-LED backlighting, but it worked perfectly with the Eizo (also W-LED) yielding perfectly straight overlapping curves. I know the P232W has hardware LUT, and that SpectraView would solve all my problems, but if the i1 Display 2 worked with the Eizo, why not with the NEC? What am I doing wrong that the colorimeter will not respond to my OSD inputs?
