NEC LCD3090WQXi problems...please help!!
Brashen
So I finally got it.....it's the sex and all that jazz.....BUT 2 problem have cropped up.
1) It won't go over 1024X720
2) The Naviset Software can't detect it.
I've searched for hours on a solution but can't seem to find one. Am I supposed two connect to DVI cables?
Oh the Graphics card I have is the 8800GTX.
Thanks guys hopefully when I fix this issue I'll make a separate thread for the unboxing pics.
UPDATE:
Apparently the version of Naviset supplied with the monitor did not support the later models. So I download the latest version and try to install it. BAM!! The software tells me that it doesnt support Vista64....There is nothing about it on the NEC site......Please HELP!!
UPDATE:
OK I got the resolution going but at 59.8hz is that normal?? Naviset still wont install.....
Generally speaking (this time it's IMO) if you want more headache - you go NVidia, less headache - ATI.
More headache - Vista, less headache - XP.
I cannot comment anything on Vista.
I have tested a bunch of monitors on XP/ATI and I don't know the word "incompatibility", etc. So I see no need in changing anything for the nearest future.
59.8Hz is normal.
Update Vista.
Update videocard drivers.
Try Naviset from different NEC sites (US, UK)
What do you need Naviset for? Maybe it's better to forget about it?
What you need is SpectraView II software and Eye-One Display2 colorimeter.
Please use 3090 thread for posting if you want your info to be read and helpful for others.
Please be constructive.
The worst feature of this forum - uncontrolled proliferation of empty threads on the subject already being discussed.
UPDATE:
I can't use naviset either - won't install on x64. As for refresh rate, surprisingly that is what my display is running at from auto detection.
Hey Albovin thank you for the info. Doesn't Naviset give us access to advanced options for the display?
Sorry I made a new thread with this header but I thought the other one was dead.
AS for the Spectra View II software I have to wait a month for anyone to stock it as I only want the software. I already have the Spyder 3 elite and yes I know it doesn't work as well as the gretag but I'm not gonna just throw it away.
Pawstar: Hmm I guess that's normal then. Thanks dude.
