NEC FP2141SB-BK settings
tigger1612
After tinkering with this monitor forever and finally finding the screwdriver that was needed for focus, i still cant seem to get the color right. I was just wondering what other 2141 users were using as their color settings for each color as well as brightness. Thanks.
each individual monitor's optimal settings vary by the monitor. Even though it's the same model, it may look different for two different monitors even though the settings are identical.
So you need to set it to whichever looks right to you.
These are my settings after a very long time (weeks) trying to get them right using everything possible.
Try my settings.
RED 81.3%
GREEN 80.1%
BLUE 79.5%
Brightness 40.0%
Contrast 90.1%
I also use set my desktop at 1280x1024 at a refresh rate of 100 Hertz instead of 120.
And download the Naviset app to addjust everything from your desktop if you havent already.
