The NEC PA-series monitors have something like a KVM, you press the input button at the bottom of the display and you can switch between 2 computers, both controlled by only one keyboard/mouse plugged into the DisplaySync Pro ports.
The DisplaySync Pro is basically a USB hub and it sort of works as advertised. The problem Im having is that I can no longer wake the machines from suspend S3 by tapping the keyboard or moving the mouse. The USB hub is supposed to be powered in S3, so resume by keyboard should work, but it wont wake either machine in Windows or Linux
Any ideas?
Any ideas?
